Problem with Lofting
I'm trying to model a logo in 3D for 3d printing.  I have the entire logo done except the O at the end which looks like a gear.  I'm offset the base 3mm and am trying to loft from the top of the model to the offset.  All of the other letters worked except the gear.
TheCADWhisperer
Wouldn't Extrude with Taper be a lot easier?
If you really really wanted to do as Loft, you would have to do as two Loft features, one for the solid and second to cut the hole.
cekuhnen
@Anonymous
As @TheCADWhisperer . extrude and taper in this case will do the job.
first loft can be tricky with less simple shapes like your gear
second using extrude and taper removes 50 of your sketches
Fusion uses parametric tools also for sketches so try to keep sketches as simple as possible and
do work with modeling tools instead
don't filet in the sketch do that with the patch solid fillet tool
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
