Problem with drill hole not showing as hidden
aaron.winship
aaron.winship
Hi everyone,
I've drawn a centre-drill and I can't seem to show it as hidden lines in a drawing. I've selected the style as hidden lines and as you can see in the attached picture, the safety centre counterbore is showing as hidden but the No#3 centre-drill isn't? Any ideas, thank you.
jhackney1972
Reduce your drawing line scale.  Maybe the lines in the center drill are to short to show with the current line scale.
John Hackney, Retired
aaron.winship
Hi John,
Thanks for the quick reply. I tried changing the line weight but I think after reading on some forums that it may be the custom template issue that some others have found. I've made drawings before with drilled holes and the hidden lines appear but this one was on a custom drawing template. I'm not sure if it's a quirk in the drawing side of Fusion but I'm sure I'll work it out eventually. Thanks again for your help, much appreciated.
