Problem with component visibilty as shaded solid
I'm machining this model engine (manual machining only I don't have any CNC machinery) and working on the 3d model at the same time, I had to put it on the back burner for 6 or so months and have recently opened the 3D model to commence work once again. I recall I was having an issue with the visibility of the cylinder heads at the time I mothballed the project. The issue is that I can only see the cylinder heads as a shaded solid if I make them the active component - if I make the whole project active by clicking on the top of the browser tree I can see all of the components as shaded solids except the cylinder heads which remain as wire frame - I've tried left clicking and "show bodies" and also "show components" with no change, I have googled it and have only found "show bodies" and "show components" which I already tried is someone able to point me in the right direction - I'm not keen on deleting the cylinder heads and doing them again, any help is appreciated.preciated .
