problem uploading stp file
it in data library but for over hour the timming wheel is still running  i have tried to delete the fie  nothing happens i have turn off fusion 360  waited and then restartedit the clock is still running
innovatenate
Autodesk Support
Autodesk Support
Have you tried importing with the local translators? If you go to the file menu in the product, there is an option for New Design from File.
I hope that helps. Let us know how it goes!
Nathan Chandler
Principal Specialist
Thank you I will try this
