Problem to seeing model
fusion 360 doesn't upload image of the modeo or even all model that I create
Mike.Grau
Hi @Anonymous,
Welcome to the Forum and thank you for sharing the screen shot.
It looks like that the design has been uploaded to the could but the thumbnail did not refresh.
Here are couple things which we can test:
1. Could log into A360 and check if your design has been uploaded?
2. If you have "Saved Copy As" Sparnuote_.., you could use the "Refresh" button in the data panel to see if this refreshes the thumbnail?
3. Another option is to manually refresh the data panel which is described in the article here:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Data-Panel-does-not-function-in-Fusion-360.html
I hope this helps. Please, keep us updated.
Tank you @Mike.Grau for your help.
I just deleted unnecessary part on my model and everything fixed itself.
I have another question. Where can I find bored engineers who would like to design something together in 3D online for fun? And is it even posible to design online with others on Fusion 360?
Mike.Grau
Hi @Anonymous,
Thank you for the update. I think this is a great idea, yes, Fusion 360 is the best tool you can get for collaborative design 🙂
You might want to reach out to a couple studenexpert´s  http://www.studentexpert.net/en/
I´d really like to see a great idea designed from several people in several countries all over the globe.
I look forward to your next post.
