Problem exporting to STL
Message 1 of 13
I have problems to export some projects to stl, the errors are the following:
Error: Autodesk Translation Services failed to translate the current document to stl file!
Error: STL Translator failed to export data
If I create a new box there are no problems but with some other more elaborate projects (not all) I can't export.
I attached an example.
I'm new to this program, maybe I'm missing some basics.
Thank you
Replies (12)
Message 2 of 13
lucasliraAU
Hello Friend!
I've been exporting your attached file to the extension in STL. in my Fusion 360, I did not find any kind of problem exporting was a success. I am attaching the file for your validation.
For you to prepare an export in STL you must select the part as shown in the attached images:
By following these steps you can implement this in other projects.
I hope it has helped you, your STL file is attached 🙂
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
Message 3 of 13
Thank you for the reply, I just tried again selecting the body but it failed again in the same way.
Message 4 of 13
etfrench
Can you make a screencast to show your selection process?
ETFrench
Message 5 of 13
I tried both by selecting manually the object and selecting by clicking on "Bodies" -> "Body1"
Message 6 of 13
I tried to modify a project that I can export correctly by extruding a couple of faces, after the extrusion it starts giving me this problem.
With a project I solved this by simply moving the body in the positive axes value region of the space, but when I tried this on others it didn't work.
I don't know what to do.
Message 7 of 13
I was just having this same problem. After random clicks, it rendered and worked for me--I had preview mesh selected. Wondering if it was an issue on the server side. Is yours working now?
Message 8 of 13
daniel_lyall
@lucasliraAU wrote:
Hello Friend!
For you to prepare an export in STL you must select the part as shown in the attached images: No you can select the top of the tree the body or 3D print under the make menu they all should just work
@Anonymous It's more than likely a problem at your end in fusion, I can not fail the stl export doing it every way possible. This is a case for the fusion support staff and what you should in your picks is correct.
It will help support if you show this fail in a screencast, and attach your error log files
@jeff_strater can you have a look or pass on please.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 9 of 13
What I seem to be seeing us an unusually long render time. It errors, but continues processing, so eventually I see it.
Note this is with multiple stl, and multiple ways of generating the stl.
Message 10 of 13
I tried to install Fusion on my laptop and there the export works...
I attached the screencast and the diagnostic logs.
Message 11 of 13
daniel_lyall
@jeff_strater Please and thank you
Daniel Lyall
The Big Boss
Mach3 User
Message 12 of 13
jeff_strater
Hi @Anonymous,
Happy to take a look.  I have the same experience as @daniel_lyall with this model.  It exports fine for me.  The export succeeds, and I can bring the resulting STL back into Fusion, and it looks fine.  Can you please record a screencast of the exact steps you take to experience the failure?  Perhaps we are doing things in a different order, or with different values in the STL dialog.
Jeff
Jeff Strater
Engineering Director
Message 13 of 13
See my previous post.
Maybe I should just reinstall the software.
