Hello all,
I have a problem trying to create a patch? I have researched online a lot about this and done some tutorials in surface modelling so I'm pretty sure it's a patch that I want. I've gone this route because I need to be able to adjust the splines later if need be and I need a G2 blend with the main body. I can get a loft to work but it won't allow me to create the G2 blend.
The connection lines had to be created by projecting geometries and they appear to be fully connected and in the correct positions. However as soon as I try to create a patch it will not even let me select both sets of lines and the ok button is always greyed out.
Any help and direction would be appreciated!
Thank you!
