Problem creating a Loft. Error: "One or more profiles have multiple edge loops"
CX15
CX15
Hi Everyone
I ran into a problem creating a loft and receives this error message:
Error:   One or more profiles have multiple edge loops.
    Try reselecting the profiles.
Error: Cannot create tool body for loft.
I attached a f3d file with a simplified version of the problem.
Body1 was created by sweeping the profile in sketch2 through 360deg around the right hand straight edge.
I then try to do the loft from the bottom surface of Body1 to the circle outline on Sketch1.
The bottom surface of Body1 is not a flat surface, so that might be causing the problem, but I cannot figure out how to solve it.
Please let me know if I should explain better.
Any inputs will be greatly appreciated.
Regards
laughingcreek
looking at the profile inputs, the loft doesn't make logical sense.  I would expect this to fail.  what is your expectation for the result?
CX15
The attached project is just a very simplified model of my problem. I'm trying to understand the error message and if I can solve the loft on these simplified objects, hopefully I can then fix the problem in my actual project.
The actual project has a similar 3d Object (with a curved bottom surface), albeit much more complicated in shape, that I have to loft to another profile.
laughingcreek
can you sketch what your hoping the end result to look like?
the wording for a lot of fusion's error messages would only make sense to a programmer.  basically fusion is getting confused on how to map the points because of the shape of the solid.
laughingcreek
Im signing off.  I suspect the attached is the result you're looking for.  when solid lofting fails, you have to move on to  more versatile surface lofting.
