probably stupid question about copy paste
When I want to make a copy of a component and modify the second copy, but not the original, how do I unlink the two copies?
I know this is probably obvious. But I am stuck for some reason.
Anyone out there who can take a second to give me a pointer?
TrippyLighting
You use copy/paste new instead of copy/paste
PhilProcarioJr
@Anonymous
If its showing up as linked after you copy it then right click on the component and select break link.
Phil Procario Jr.
Owner, Laser & CNC Creations
HughesTooling
If you're working with Capture History on, after making a copy you can't break the link, only option is delete and Copy\Paste New as @TrippyLighting suggested. If you have record history off you can use Make independent to break the link.
Mark
Mark Hughes
Owner, Hughes Tooling
