I am trying to print a 1:1 of sketch for use as a template to cut out plywood shape. Of the methods presented from the help query results it appears that the path I should use is File->New Drawing->From Design and in dialogue box uncheck "Full Assembly". Then select the sketch and proceed. I either get a blank drawing or if leave the "Full Assembly" checked a terribly pixelated image.
Any suggestions?
