I have a 6040 cnc running planet cnc and I keep getting error messages.can someone help thanks
Solved by jhackney1972. Go to Solution.
Can you attach your model please. If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
I will not be able to help you due to the fact your toolpath configuration use the Fusion 360 Machining Extension which I do not have. You will be better off posting your question to the Fusion 360 Manufacturing Forum, that is where you probably will find someone who has the extension and can help. You will find the Forum here.
