post processing error
lucas.sealing
Message 1 of 13
lucas.sealing
hi all
went to drawn up and plasma out a simple bracket for a fuse block, drawing done, setup ok, 2d cut op ok........but when i come to post process it it has a moan. ive cut out at least a dozen things using the same process but this is a first can anyone help?
cheers
lucas
Replies (12)
Message 2 of 13
a.laasW8M6T
Hi
Can you tell us what error message you are getting?
Also which post processor you are using?
I can get your file to post out just fine using the Dyna torch post, but without seeing the error message or post we cannot help.
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 13
lucas.sealing
ah ok this is my error message an im running the openbuilds grlb fusion360 post
Error: Mismatching arguments for invocation of 'string VariableImpl.format(Number)' (Value is not a number.).
Error at line: 1347 (OpenbuildsFusion360PostGrbl.cps)
Error in operation: '2D Profile2'
Warning: (OpenbuildsFusion360PostGrbl.cps:277) Setting read-only property "power" on object of type "PostProcessor". This will have no effect.
Warning: (OpenbuildsFusion360PostGrbl.cps:906) Setting read-only property "power" on object of type "PostProcessor". This will have no effect.
Message 4 of 13
a.laasW8M6T
Hi
If you download the latest version of the openbuilds post this error should be fixed
https://github.com/OpenBuilds/OpenBuilds-Fusion360-Postprocessor
Andrew Laas
Message 5 of 13
lucas.sealing
cool thanks when was it released? i was cutting last week
Message 6 of 13
a.laasW8M6T
looking at the release note that bug was fixed 27 march
Also depends when you updated to the latest version of Fusion
Andrew Laas
Message 7 of 13
w_kapel
Hi, i had the same problem and use now the latest grbl post processor. When i save the gcode its okay now, but when i load it in Openbuilds Control it wont run. Simulation going good, running the job not. Gcodes what i before made with Fusion 360 run flawless, but with Fusion fail so what more can i do? Best regards, Willem.
Message 8 of 13
programming2C78B
Do you mean simulation in fusion or OBControl? Any errors? Did you update anything lately?
Please click "Accept Solution" if what I wrote solved your issue!
Message 9 of 13
w_kapel
Hello, i mean in OBC the, gcode wont run. I have recently update Fusion, before a had Fusion360 and it works flawless with the gcode that i made with this version. After the update to Fusion it wont run the gcode anymore in OBC. When i push the run button in OBC nothing happend and no errors. Try different things, re install Fusion and OBC (with OpenbuildsFusion360PostGrbl.cps 1.045) but the problem stay.
Message 10 of 13
programming2C78B
My first guess is Fusion updated the Post and now its not compatible. Try an old version
Message 11 of 13
w_kapel
I tried a version before and that is Openbuilds CNC:GRBL/BLACKBOX: Post V1.037 post processor. When i this use a got this errors:
Warning: (OpenbuildsFusion360PostGrbl.cps:1038) Setting read-only property "power" on object of type "PostProcessor". This will have no effect.
Error at line: 1767 (OpenbuildsFusion360PostGrbl.cps)
Failed while processing onCommand() for record 321.
Error: Failed to execute configuration.
Stop time: Friday, October 3, 2025 10:07:58 PM
Post processing failed.
When i use the latest one Openbuilds CNC:GRBL/BLACKBOX: Post V1.045 the errors are gone and it save the gcode. But then i got the problem with OBC not running with this gcode. Very strange.  What i see is by the  line Warning:(OpenbuildsFusion360PostGrbl.cps:1038) i read cps:1038, i use the 1037 version is this the error maybe?
Message 12 of 13
a.laasW8M6T
Hi
Th Open builds post processor is not developed by Autodesk so you need to feeding back these issues to the post developer.
I suggest contacting them here:
https://support.openbuilds.com/support/home
Andrew Laas
Message 13 of 13
w_kapel
Thats a problem because Openbuilds is not anymore, they stop and the forum is not working is what i experience. I can not place a new topic or so.
