possible mirroring bug
AagAag
AagAag
I am trying to mirror a pattens of hexagonal holes across a plane. The mirror, however, is incorrect. Is this a bug, or am I doing something wrong? See screencast. Also, the downloadable link to the model is: https://a360.co/374Qnrp
janus2
Sorry! No Screencast!
Jan
AagAag
oops, sorry, Screencast should now be available. 😉
GRSnyder
Can you export the file and attach it here? Just going through the timeline doesn’t give much insight into how you’ve defined the features.
Beyondforce
Hey @AagAag ,
From the Mirror dialog box you just need to chose "Optimized" under "Computer Option" and it will work.
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Need a new computer? Fusion 360 Hardware Benchmark: TESREG.com
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
| YouTube
AagAag
Magics! "Optimized" did the job! Thanks a million!
AagAag
done
