Possible Bug with Draft Angle not supporting value from Parameters
1 REPLY 1
justincooney
269 Views, 1 Reply
I created a parameter called Draft_Angle and gave it a value of 5.0
I selected the "pull direction" and "face" of a cube, and for "Angle" starting typing Draft_Angle... It autofills the parameter but then turns red and i cannot click OK on the menu to finish.
I really feel like it wants to work but seems to only accept numeric inputs.
Labels (1)
1 REPLY 1
jeff_strater
in reply to: justincooney
what type of units does your parameter have?  It must have some type of angle units (degrees, radians) to be a valid value for draft angle.
Jeff Strater
Engineering Director
