possible bug: sketch constraint parametric not working
cekuhnen
Mentor Mentor
cekuhnen
I made sketch 1
make sketch 2 3d included curves from 1
make blend curve with G2 constraints
edited sketch 1
blend spline does not follow
KABOOOM
https://drive.google.com/file/d/0Byzv_NlyKp_2TDBvcDhmRVlWSUE/view?usp=sharing
looks to me know seeing also other features not updating correctly there there is maybe some bigger problem under the hood with the parametric system ...
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
jiang_peng
Thanks for reporting this. This bug is slightly complicated than the other two. Currently we put most of effort in fixing constraint solver problems. I will log a bug but cannot guarantee if we can have the fix on next update.
As a workaround, you can simply deactivate the tangent handle at the point. The operation will trigger the recalculation of the spline.
thanks
cekuhnen
Thanks for the heads up
Claas Kuhnen
