I want to create a hole in a body with a curved/warped surface. As it's curved, I can't direcly create a sketch on the surface.
My idea was to create a point on an YZ offset plane, project it to the surface and then use fusion's hole function. But I can't get this to work.
The reason why I don't just want to extrude a hole from this YZ offset plane is, that the hole would then go horizontally through this surface. But the surface is not vertical.
My ideal would be that the hole "automatically" is positioned orthogonally to the surface. The YZ offset plane would just be used to set the starting point of that hole. Is this possible?
Here's a screenshot:
Any help is much appreciated. Thank you 🙂
