Plus Plus Tolerance
Plus Plus Tolerance
percyengine98
Plus Plus Tolerance
percyengine98
The only way I've found to get a +/+ tolerance is to put in a minus, is there a logic I'm missing?
g-andresen
That's the way you found out!
günther
percyengine98
So you're saying there is a logic to it?
g-andresen
If you judge from the lower and upper deviation, that's true.
günther
percyengine98
OK, so the input is true once you know that one is relative to the other, but user friendly? I don't think so 🙄
percyengine98
TimelesslyTiredYouth
Depends on the user's experience with Fusion, you wouldn't see an everday begginer using tool as such for example...
