Hello, I am having troubles with the planet gears, if you rotate the sun gear the planet moves but they do not rotate correctly so I can not do a motion study. Another thing is that I want to change the ring thickness because I did 1 mm and I need it as 2 mm but I don't know how to do it or if that affect all the design (the other gears). I will attatch the file in case you guys need it to have an idea of what I need.
Thank you!
