Piping and Sheet Metal
paolo.recchi
paolo.recchi
does nobody here need to have a more professional Piping and Metal Sheet modules?
I'm trying to explain:
Piping do not gives possibility to use commercial sections, and not gives possibilities to choose what happens when more pipes crossing each others
Metal sheet design not get possibilities to make edges like linear welded that I have seen on inventor
even with these two improvement I think F360 could grow so much!! (since is already one of the best)
THX
piotr.kornafel
Autodesk Support
Autodesk Support
Hello @paolo.recchi
For now, these features are not available for Fusion 360 in standard.
About piping, here you will find a link to the official Autodesk app store: Structural Member can be this what you looking for.
What's more, If you want to share your ideas with our developers I suggest you follow this link:
Below you will find an article about :
How to use the Fusion 360 Feedback Hub
Piotr Kornafel
Global Product Support
 Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
paolo.recchi
Many thanks for your kindly reply.
I'm going to write to hub for that, I was a bit not sure where was the best place to leave that, by the way your suggestion it's really helpful, unfortunately  "structural member " is not delevoped for MAC OSX user, so sad.
In any case in my opinion a piping and sheet metal functions a bit more pro should be a part of any modern CAD, because I think it's not a plus or for niche user, but I think, a normal routine on a CAD design.
Many thanks
