Message 1 of 1
Pin-slider options
I'm obviously missing something simple here. I've got two of the six spokes and braces working like I want them to (blue for ref) when I preview the main slider joint in the center, but the other four pins aren't staying in their slots. Can't for the life of me figure out what I'm doing wrong. If I preview the rotation on the correctly working joints, the spoke rotates around the pin, whereas on the others the braces slide and rotate around the pin. Is there some way to select which component does the movement, and/or is that even my issue?
Thanks in advance.
Cheers
UPDATE: I found that by selecting the spoke first when starting to make the joint made it work as desired.
