Wondering if anybody could show/explain to me how to create equal spacing using pattern function or another method to achieve my goal. I do alot of shop drawings for hand rail that have multiple pickets so drawing each picket individually is obviously time consuming and tedious. I've looked at a few youtube videos on the pattern function and cant find a video or explanation that solves my problem. In this drawing specifically, I need 3-3/4" space in between each picket. I drew the first two pickets with the spacing I need and cannot figure out how to use the pattern function to create the same 3-3/4" gap in between the pickets. In most cases the space between the end pickets and the posts end up different than the 3-3/4" and that is acceptable as long as the gap is the same on both ends. I think I need to start my picket design and spacing from the center out to achieve that. But for now, I am just curious how to achieve equal spacing between the pickets. TIA.
