I know right away people are going to say you can't do anything on a path for sketches. This is why I am consulting the oracle. I am trying to make a cribbage board, the lines for every 5 points are easily cut in CAM with a trace operation so I need the sketch to reflect what will be the CAM. Also, I would like to automate the lines somehow to stop me from having to manually add 69 of these lines for the three player set.
I have thought about creating bodies and then 'pattern on a path' but there is no way to do a body without having more than 1 line translate to the sketch with project. ie. a rectangle will project two lines between the 5 points not 1. Then I would have go back through for even more manual work.
I have attached a screenshot and the .f3d of the project.
An easy way to do this in Fusion has to be possible, I must just not be thinking creatively enough. Any help would be appreciated!
Elliott
