Perpendicular constraints, lines to curves
domusam
Observer Observer
domusam
Observer
Observer
The title describes the thing. Why is it not possible to have a line perpendicular to a curve? It seems like such an elementary feature, that to not have it makes a mockery of Fusion 360 and Autodesk! (perhaps that's a bit dramatic, but you get the point).
TheCADWhisperer
@domusam
I have demonstrated how to do this here in the past.
A search might return the discussion thread(s).
wersy
I have never thought about this before because I have never had this situation.
A work around is quite simple. A circle around the desired point gives the intersection points for a chord. From there, as usual, a perpendicular line can be created.
@TheCADWhisperer, is it this what you mean?
TheCADWhisperer
The chord is not needed in the case of a circle - a line perpendicular to a circle would always point through center.
Simply add a Coincident between the line and the center of the circle.
This connection point can be dragged around the circle and the line remains perpendicular to the circle.
wersy
Yes, of course, that's right.
Then all that remains is the perpendicular to a curve that is not a circle.
davebYYPCU
Your method is used on Splines, here.
Might help
matthewM5R6M
How has autodesk not implemented perpendicular constraint to an arc, or circle yet?!?!?!? I could do it on inventor for as long as I can remember, but fusion 360 lacks this?
