Perforated surface
Perforated surface
Message 1 of 14
Perforated surface
I am trying to create a rectangular surface with a circular perforation. The target is not a 3D object, but a surface. Can anyone please help me with this?
-Dennis
Replies (13)
Message 2 of 14
Beyondforce
Will you please write the dimension of the rectangular surface and the diameter of the circular perforation?
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 14
Beyondforce
Is that what you are looking for?
Cheers / Ben
Ben Korez
| YouTube
Message 4 of 14
it's 310 by 250mm and the circle is 80mm diameter
Message 5 of 14
Beyondforce
Have you looked at the screencast?
Ben Korez
| YouTube
Message 6 of 14
yea, from that point, is it possible to subtract the area of circles from the rectangle underneath?
Message 7 of 14
Beyondforce
Yes, just don't select the circles when you extrude. 🙂
Ben Korez
| YouTube
Message 8 of 14
i used the cut option with extrude, but it seems to be applicable only if
the target is a 3D object
Message 9 of 14
Beyondforce
In order to use the sketch for anything, you must extrude it, else it just a sketch 🙂 If you don't want to create a 3D object, then what do you need the sketch for?
Ben Korez
| YouTube
Message 10 of 14
I wanted to know if it's as effective as CAD software that produces IGES
files. I need to use it in ANSYS APDL where I'll be able to assign depths
and thicknesses inside the software.
Message 11 of 14
Beyondforce
Unfortunately, I'm not the right guy to ask this question. But @TrippyLighting or @prabakarm could help you with that?
Ben.
Ben Korez
| YouTube
Message 12 of 14
Thanks for your time anyhow :]
Message 13 of 14
Sorry but I don't know enough about the topic but I would look into User Parameters. I hope this helps!
Message 14 of 14
jeff_strater
Hi @Anonymous,
I think what you are interested in creating is a surface body - which will export to IGES.  Here is a screencast that takes up where @Beyondforce's stops:
Jeff
Jeff Strater
Engineering Director
