Pepper grinder
Pepper grinder
jonhutty
Pepper grinder
jonhutty
Hi all I am a beginner using fusion 360 but I am learning, but at the moment I need your help. Has I have sketched the main big circle and started doing the 6mm smaller circles in the larger circle. I need to know how to go about getting them equally spaced between each other smaller circles and also how too get the smaller circles from the larger circles edge at 2mm distance from the edge to edge. So I hope someone can help on this has I am now stuck on how to get every circle in the correct position.
jhackney1972
Please attach the Fusion 360 Model you have done so far to  help the forum users make sure you are starting out correctly.  What it sounds like is you need to consider a circular pattern.  Normally it is better to pattern solids rather than sketches so it really would help to see your model.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
jhackney1972
Here is what I hear you saying so you can see why it is important for you to attach you model.
g-andresen
This is how such a sketch is created
Screencast
But it is better to sketch only one instance and create the pattern with an extrusion (hole..)
günther
jonhutty
I'll attatch it tomorrow but I think I have now sussed this question out myself but will still post just to see if I have it right or not thanks for the replies
