PDF not at the right size
jean-michel_legoff
jean-michel_legoff
Is anybody boring by the small distorsion of the PDF size vs DXF size?
In a PDF a 50 mm line is actually  50,038
and in PDF it's perfectly 50,000
I know its not a lot, but it's just boring in some case.
My issue is that it's not possible to export all the sheet in DXF at once.
Only PDF allows it
and DWG is not an option neither
Warmingup1953
Can you share your Fusion file? When creating your .pdf from the Drawing Workspace, are you checking or un-checking the lineweight radio button? Does a 100mm come out as 100,038?
