Patterns around a table
I have a circular shape (a table) and would like to do a pattern of circles around the edge in a 0.02 radius deduction. So, that the circles decrease in .02 sizes around the table. I don't want the same radius. The closest pic I could find was this image below. Thanks.Inv002_Pic24.jpg
etfrench
The hard way:
  1. Do a pattern of a row of circles.
  2. Delete the pattern constraint.
  3. Dimension each circle.
  4. Repeat for each row.
I can't think of an easy way unless you create a script using the API.
ETFrench
I will try that. I figure API might be an option but haven't looked into it yet. Thank you for your post.
chrisplyler
You will have to dim each hole separately. The pattern cannot have separate values.
But something to make it easier might be to set a user parameter "dr" equal to 0.02", and then dim each successive hole as <click on prior hole dim> - dr so as you go around the table it's quick and easy. Plus then you could change the reduction value all around the table with one parameter change.
