I have a single panel designed. Within this design there are two posts, and a four-sided channel insert with wire mesh in the middle. I also have a full assembly of posts, but they all have different spacing. Therefore I cannot just make one channel insert and insert derive into my full assembly multiple times. I am wondering if there is a way to maintain my single panel design (height needs to stay the same but the widths will vary) and "insert" them between the posts on my full assembly project. The way I planned on doing this is extremely time consuming and tedious (drawing a channel insert in between each post). I am wondering if anybody has a suggestion to make this process more efficient. Is there a way to use "configure" to get this done? TIA
