05:06 PM
Anyone,
I need help inserting the "plus" formation pieces into the bottom layer. Both materials are 2 inches thick. I want the "plus" pieces to fit inside of the bottom layer flush with a little bit of offset. The "plus" layer is in blue and there are five pieces that are 8" x 8". The thought of the sketch is each of the square foams can be removed. There is no bottom. The square will be flush at the top and bottom of the material. Drawing is below. Probably easy for an expert.
