Hi Forum
I'm doing a Pattern on Path with 'Extent' as my distribution method. I would like to have the first and last object at the start and end point of the path I'm using. It is only possible to type in an exact distance in mm or use the hidden 'measure' feature next to the type field, though my path consist of multiple tangent lines and I'm not able to 'measure' the hole path at once. Is there a way to set the distance for the 'extent' as a percentage of the path? (in my case I would like to set it at 100%) I can eyeball the extent distance to match the length of my path but this is not exactly the nature of a CAD software. I am not able to attach my file unfortunately but again this address the features of the tool (Pattern on Path) in general more than my specific file. I have attached a screenshot of my issue, though. EDIT: I have attached the section of my file in question.
Best regards
Rasmus
