I'm trying to draw a simple Adirondack style chair as practice using Fusion. I've managed to draw it, making a few mistakes along the way. One thing I can get right though is the seat slats. The first picture shows what I achieve by manually moving components (not right, I know).
I think that the Pattern on a Path command should be the right one, but it's not working for me as I had hoped. If I select the Orientation as Path Direction, I get the effect I see in the second picture, with the slats orientated wrongly, even if they do follow the path.
Can anyone tell me either how I use this command properly, or what other tools I could use to achieve the same?
Neil
Olivewoodturning
