pattern object to point
Hi, first time posting on the forum. I use SW professionally and 360 casually at home. I'm wondering if there's a way to use the pattern feature to pattern along a vector/line up to a point - and then adjust how many times the body is patterned between the 'end point' and the original body/reference along the selected vector/line. This feature is supported in SW but the only way I'm finding to do this in 360 is by move/copy to point. this entails I have to do move/copy a number of times with many reference points instead of referencing the end point and ref/start point and then patterning with an adjustable feature. any thoughts on how if this is doable in 360? thanks!
docara
Welcome to the Forum 🙂
O.K. I've just had a quick play with a body and a sketch line for the path
Follow the 'Create > Pattern > Pattern on Path' then  'Distance Type > Extent'
Annoyingly, there is no Snap type function or 'To Object' like in other commands and it just uses the path line as a finite length input, so I used the measure option under the 'Distance' prompt to nail the length of line.
Interestingly, although I use an underpowered PC to learn Fusion, it still took many seconds to be able to select the path line after I used evoked the measure command from the dropdown mentioned above.
Matt
benrogmans
Snapping to object would be so useful! It would save a load of work of tediously repeating components, that I do now to keep things parametric 🙂
g-andresen
Please start a new thread for "your" use case and add an f3d file in the attachment.
günther
benrogmans
I have worked around it by transforming my constraints into formulas that I put as parameters. By doing so, you can use the "Extent" option in pattern on path and use your parameter.
