Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Pattern Error
5 REPLIES 5
5153 Views, 5 Replies
Pattern Error
Hello to everyone, Im trying to create a pattern but appears this error "Error: C-Pattern 1 Compute Failed" any advice?
5 REPLIES 5
 Please try setting the "Pattern Type" to "Bodies" and then reselecting the objects you want to pattern.
(I believe the error is due to not making a "Watertight" selection.)
lichtzeichenanlage
@Anonymous: But using faces is smart, because Fusion 360 processes them more easy / faster than bodies. Features might be a alternativ.
in reply to: lichtzeichenanlage
@lichtzeichenanlage: I was not aware that faces were faster. Can you provide further details?
I think @Anonymous can achieve can achieve his result with faces as well but he'll need to be more careful in making his selection. It's easy to miss a face and not realize it.
miguel.palma82
@Anonymous could you share your file? to try to help
Miguel Palma
Autodesk Student Ambassador
Thanks.. this solved my problem
Technology Administrators
