Pattern around corner
baden9UXUY
baden9UXUY
How would you continue this pattern around the corner? And have the feature blend at the corner?baden9UXUY_0-1710780716390.png
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
TrippyLighting
Even with a model I'd have a hard time visualizing what you mean with "around the corner" and "blend" in reference to the screenshot you provided. What corner ?
etfrench
Circular pattern.  Blending will depend on well you modeled the left and right sides of the current pattern.
ETFrench
