Pattern around body with different planes
This widget could not be displayed.
If I have a box and want to pattern a sphere on one side to all sides, how can this be done? When I try it is only done at one plane. Is pattern not the right option?
I see if I set a point at the center and construct an axis through this point and use a circular pattern set to 4 it works.
jeff_strater
You can also use Pattern On Path, with an orientation of "Path Direction" to achieve this:
Jeff
Jeff Strater
Engineering Director
