Pattern across multiple bodies?
Hi there!
Is it somehow possible to create a pattern across multiple bodies? I'd like to use the pattern function to create the slots you see in the screenshot on every panel, but I can't get it to work. Any ideas?
Thx! Jasper
jeff_strater
no, unfortunately, you cannot pattern faces across bodies today.  You can pattern them as bodies, and do a combine, or you can change the order of your patterns (pattern the slots first, and then the bodies of the larger bars, with the slots in them)
Jeff Strater
Engineering Director
Hi Jeff,
Thanks for the reply. Those options will work too, thx!
Cheers, Jasper
