Path on inserted SVG ignored.
cdaviesbarnard
cdaviesbarnard
Apologies for the simple question.
I'm trying to select the letters below and the first O will not select correctly.  I can select the parts and make a complete 'little' o but this is not respected by the big O surface?  I'm sure there must be a complete path or something command I should use to correct the error but this is where I get lost.
The adjacent O selects correctly
Thanks for your time helping me.
Regards Chris
g-andresen
This points to a faulty inner profile.
1. delete 1.   O and  copy&paste the 2.
2. please share your design
export > save as f3d locally > attach to next post
günther
cdaviesbarnard
Hi Günther,
Thank you for the quick reply.  The file should be attached as requested.
Regards
Chris
g-andresen
divide and conquer is your friend
Screencast
günther
cdaviesbarnard
Thank you muchly.
I'm going to have to review your screencast a few times but brilliant.
Thanks again!
