In surfacing a .1 mm gap is generally considered a huge hole. In Autodesk Alias the default stitching tolerance is 0.001 mm.
When attempting to stitch this, Fusion 360 will show the maximum gap is is detecting:
So in essence the stitch tolerance needs to be bigger than the gap, so maybe .35mm. While this does not sound like much and perhaps for manufacturing purposes stitching might be OK, which is what I suggested im my last post.
Generally, as I've explained above already the default stitching tolerance in Fusion 360 is already very large. This was likely done so that people unexperienced in proper surfacing techniques can create some surfaces. The maximum gap here is more than three times this so it is prudent to find the root cause.
Comparing two bodies in Fusion 360 by overlaying them is really not the correct technique to evaluate surface quality as you are comparing two somewhat randomly tessellated geometries.
First you should check the curvature of the edges before and after stitching with the curvature comb inspection tool. The Zebra Stripe analysis and the curvature map can also provide valuable insight into quality of the surface. That's where Fusion 360's tools end.
In order to make sure these display at the highest quality you should also set the display detail control of the geometry in question from adaptive to fixed/high.
This model also exhibits another indication that the modeling techniques need improvement. Many of the curved edges are quite broken into short segments, which really should not be the case for this relatively simple geometry.
