Patch Type Dropdown, What is the difference?
matthewrjacobs
matthewrjacobs
@jeff_strater - I noticed something new in the patch command. When I click on the Analysis Tab and switch back to Feature Tab,  a new "Patch Type" drop down appears, see below? So I guess I have two questions:
1.  Is this a bug that it doesn't appear when the dialog box opens?
2. What is the difference between trimmed and bounded patch type?  Under the hood,  it still looks like the patch is a rectangular shape that is stamped out to fit the edges.
No Patch Type
Patch Type after switching to analysis tab
jeff_strater
yes, I believe that is a bug.  Good find!  I'll report it to the team that added the Analysis tab - I think you are right that it is related to that new functionality.
Jeff Strater
Engineering Director
matthewrjacobs
Thanks Jeff.
Any insight on question number 2?
"2. What is the difference between trimmed and bounded patch type?  Under the hood,  it still looks like the patch is a rectangular shape that is stamped out to fit the edges."
jeff_strater
I had to do some research.  The first point is:  This part of Patch does not work well.  You have to go to Analysis to even see the UI, but also, it seems to be ignored when you hit OK (or it always defaults to Trimmed).  But, the basic idea is:  A Trimmed patch is over-built, and then trimmed back to the selected boundary.  While, a Bounded patch is built exactly to the selected boundaries.  That can lead to a less-smooth result.  See the screencast below, which shows the difference (although that goes away when you hit OK, because of the bug above)
Jeff Strater
TrippyLighting
Well, the "new" version might not look great quite yet, but I for one find just the attempt to create better patch surface quality very positive and a promising, solid step in the right direction!
matthewrjacobs
Thanks Jeff.   Seems like bridge between Patch and Loft,  hopefully they can get it squared away.
