patch curvature failure - only G0 positional
cekuhnen
Mentor Mentor
cekuhnen
so I went through the pain of doing a full 3d sketch in Fusion so I can do a sweep rail like surface
and then the patch command ignores the curvature settting when closing the holes.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
innovatenate
Autodesk Support
Autodesk Support
Claas,
Thanks for reporting this. There appears to be something wrong here with updating the continuity type in the Patch command. I'm reporting an incident to development. If you select the continuity type before selecting the work space geometry, the patch will work as intended. See the below ScreenCast for more detail.
Thanks again for reporting this! I hope this helps.
Nathan Chandler
Principal Specialist
cekuhnen
hey thanks!
pleasure doing bug hunting - Autodesk should give me medal 😉
Claas Kuhnen
innovatenate
Autodesk Support
Autodesk Support
I received an update on this one.
When I was editing the patch in the above video, I had selected a sketch spline to create the patch instead of the edge of the surface. I'm not even sure that I noticed a sketch was there! **slaps forehead**
Anyways, this was causing the issue with the continuity type. I suspect this may have been the issue in the original post, as well. If you hide the sketches and select the surface's edge, can you reproduce the original issue? ... I haven't been able to so far now that I'm aware of the sketch.
I hope this helps, thanks!
Nathan Chandler
cekuhnen
oh boy we are heros ....
sure there was the sketch (double slaps forehead)
Claas Kuhnen
