Parts List into a Drawing Template
o.briggs.1
o.briggs.1
Is it possible to add a parts list to a drawing template? I would love to have the parts list be added on each drawing I do as is the case with the title block etc. I am able to create a custom table that is added but there is no option for the parts list. Is there a way to add a parts list table to a template so that each drawing I do has the parts list already there rather than needing to add it each time?
thanks
g-andresen
if you add a placeholder, the custom list is a parts list
günther
ClintBrown3D
Hi @o.briggs.1
I put together a quick video that explains a bit more about smart templates (including placeholders for Parts Lists)
Here's more information on using first level and all level templates:
https://clintbrown.co.uk/2021/04/06/smart-template-all-level-drawings/
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
o.briggs.1
thank you both! that worked brilliantly! The only issue I am now having is being able to edit the size of the text in the table. is it possible to make the text size in the parts list smaller?
thanks!
ClintBrown3D
Hi @o.briggs.1
Text Height groups control all text in the drawing, have a look here: https://clintbrown.co.uk/2021/09/04/edit-balloon-sizes-text-heights/
Clint Brown
o.briggs.1
that is perfect! thank you. Its a shame you cant define the specific number and can only choose form the drop down but it works well enough! thanks
