Parts collide in simulation
I have ran a simulation between two bodies and its showing the two parts. They are passing the part boundraies that could affect the simulation outcome. I tried to add a contact of sepration and sliding. Is this right and how do I stop it?
josef.kucera
Hi @Anonymous,
here is a link where you can learn more about contact types: http://fusion360.autodesk.com/learning/learning.html?guid=GUID-B43E60CD-1859-4A09-9AD4-394525DAA2D7
For instance if bonded contact were made between two bodies/components (two faces) they should not penetrate/collide to each other.
The penetration could happen if a deformation scale is too big, try to set up deformation scale to Adjusted.
Josef
Josef Kucera
Fusion QA
Similar issue.
I have parts passing through each other:
  • I have set contact surfaces to separate and slide.
  • I have tried adjusted.
josef.kucera
Hi @Anonymous,
could you share your design so we can look what's wrong?
You can DM me to josef[dot]kucera[at]autodesk[dot]com.
here is a tip how you can share your design: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Josef
Josef Kucera
Fusion QA
