Partial shadow?!
Partial shadow?!
Hrvoje-
Partial shadow?!
Hrvoje-
This body has an partial shadow?! I am trying to find the reson for that.
Kind regards,
Hrvoje 🙂
TrippyLighting
I would too, but without a model ....
MichaelT_123
Try invert normal of surfaces ...
MichaelT
Marco.Takx
Hi @Hrvoje-,
You can use the Reverse Normal command on the Patch Ribbon -> Modify.
This command flips the front/back of a surface.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Hrvoje-
Thank you, Marco! How simple... My ignorance is limitless!
Kind regards,
Hrvoje 🙂
melvinbrian3d
@Marco.Takx wrote:
Hi @Hrvoje-,
good tip!
MelvinBrian3D
