- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Melden
Hello, i'm having an issue with a "simple" sketch that consist of several rectangles joined with chamfers/arcs and an angled section.
The angled section i made a rectangle, used coincident constraint on the bottom right point to the bottom left corner of the C-shaped piece on top, then filled the top gap with a 3-point arc.
Aftr that i filleted every corner.
The issue is that somehow, that angled portion is unconstrained!, and i have no idea why(changed all the inner part of the rectangles that touched each other to construction lines where applicable).
The second issue that this generates is that i want to extend the bottom 75mm part towards the left, but if i change the length it extends to the right(correctly extending the top parallel part, at least that's ok)!.
And ofc the sketch remains unconstrained
Gelöst! Gehe zur Lösung
