Part lists and Physical Materials
It seems I'm having a bit of an issue in the 2D Drawing workspace. It appears that there is some kind of bug with the physical materials in the rendering workspace where I can not remove and unassign any materials at all. Not to mention the fact that I noticed that when I created a parts list that every single part was listed as having Steel material, and I never assigned any of my parts a physical material at all, but just an appearance.
It also strikes me as odd that I can not just manually adjust what parts and what materials I want directly from the parts list if I know what they are. Some of my components shouldn't really be in the parts list, but I require them to be components to use some functions in the program, so that my 3D model can be what I want it to be. Which is why I need other options, and I should also mention that there aren't enough physical materials to choose from like it is with appearance textures. For example, I need some kind of foam material that I can choose from, or different types of leather, but non of those options are that, and its important that I have those for the materials listed on the parts list.
I really need some assistance with this, so if someone could gladly lend a hand I would appreciate it.
TrippyLighting
Here is a little screencast thst hopefully helps,
For the most part that helped, although how exactly do I remove the parts I don't want to be on the list removed from the list?
