Message 1 of 22
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an existing assembly that I would like to paramatize. There are 6 parts in the assembly and each part already has variable dimensions in the "Change Parameters box". To change the assembly means going through each part, changing the dimension, updating it and then updating the assembly, then if this is part of a larger assy, updating that. I am aware that global parameter change is possible if the assembly is drawn in components but in some cases I prefer to draw individual parts and then assemble them. When I do this the data is lost in the assembly "change parameters" box. Cheers Gordon
