Parametric intersection
kubot_dev
kubot_dev
Hello all fusioners,
I want to make a sphere like dome which is created by many retangle elements which are driven by parameters.
First i made a dome and then i created a rectangle after i used pattern and on the end i want to keep intersected "rectangles" with the dome. When i change the number of copies i have to manually select bodies which i want to intersect. Is there any way how to select all the bodies to intersect? See attached fileintersect_boolean.png
laughingcreek
one way would be to attach your fins so they are a single body before the combine.  see attached model-
kubot_dev
Thank you. This is the way it can work. I wonder if there is any other solution.
