Parametric fingerjoint box
edvinburegren
Message 1 of 10
edvinburegren
Im trying to create a fully paramtric 6 sided box with user paramters for
L x W X H
Number of tabs in L x W X H
material thickness
Im using 6 extruded sketches to visualize the finnal box and sketch patterns to clone the fingertabs created using the line tool and constraints.
My problem is that whenever resizing I get both sketch and extrude errors.
Is this to much to ask of fusion to be able to have the whole model parametric and working without having to redo extrutions every time I change the size ?
Cheers
Edvin
Replies (9)
Message 2 of 10
kate.raskauskas
Hi @edvinburegren,
Can you please attach your design as an *.f3d so I can take a closer look at it?
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
Message 3 of 10
edvinburegren
Post edited I found the first error
Message 4 of 10
daniel_lyall
@edvinburegren When you do the thinger pattern use a feature pattern, useing a sketch pattern can sink fusion.
Just make sure you tie the variables together so if you change the height the thingers will move with the change or the other way around.
The attached file is just one way to do it.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 5 of 10
PuaNow
Community Visitor
Community Visitor
Did you ever finish it?
Message 6 of 10
daniel_lyall
who are you asking
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 10
PuaNow
Community Visitor
Community Visitor
the Original Poster.
Message 8 of 10
chrisplyler
Message 9 of 10
david_schenk
Community Visitor
Community Visitor
Can you post the link to the above video ?
Message 10 of 10
TheCADWhisperer
