Parametric component descriptions
Message 1 of 10
I'm loving using 360 and am building a very nice complex workshop design using the parametric design tools.
Can anyone show me how to use a parametric description for a component so that the table in a drawing will update with the desired information?
IE, I have some lengths of material in my design whos dimensions are determined by other factors in the design. Therefore, being able to set the description in the Component Properties panel to say "StudLength" would be hugely beneficial as I wouldn't have to manually update every description if a couple of parameters change.
Does that make sense?
Replies (9)
Message 2 of 10
g-andresen
please share your design and tell us what dimensions you are Talking about
günther
Message 3 of 10
Hi Gunther,
I'll sort it when I can get on my machine later today. Though I'm not quite understanding how that will help answer my question?
All I want to do is use parameters in a components description. So the parameters might be
P1: 50mm
P2: 30
P3: P1*P2 = 1500mm
The items description would be just "P3" rather than me having to go in and manually add "1500mm" into the description box and it show on the table in the drawing.
This way if I were to change P1 to 55mm, the value of P3 would change, as would the description for any component that uses P3 in its makeup. I wouldn't then have to go back to every component and alter its description manually.
Message 4 of 10
jeff_strater
I don't think it is possible in Fusion today to use parameters as values inside of a drawing table.  I will check to make sure, though.
Jeff Strater
Engineering Director
Message 5 of 10
Sebastian_Galo
Just as a hint, this is a really interesting approach that would be amazing to have in fusion! I literally had the exact same idea 5 minutes ago and tried it out in my hopes that it was already implemented.
Well, maybe one day 🙂
Message 6 of 10
Sadly it seems it's not possible or likely to happen if its just me and you!
Baffling to me that you can't do it though.
Message 7 of 10
Lennart_Losjo
Put in on the fusion 360 ideas. I want this to happen too.
Senior Product Specialist
Fusion 360, Inventor.
Message 8 of 10
TrippyLighting
And where would that be?
Message 9 of 10
Lennart_Losjo
Fusion 360 Feedback Hub - Autodesk Community<>
Sorry i forgot the "name change"
Message 10 of 10
fk_cad
was this ever implemented in an update?
