Message 1 of 9
Hi there,
Stuck on a project.
When i change the 'length' parameter, The geometry in Sketch 1 shifts around even though the geometry seems fully constrained.
also,
Ive had to constrain every connection individually. When using the mirror command. The model grinds to a halt and fusion starts crashing.
In our work we often make models containing dozens or even hundreds of parts. being able to use the parametric feature is a gift but i keep running into bugs and limitations. Is there a more efficient way to model multiple copies of parts. Maybe something like instances in C4D.
Hope you can help.
Tnx
Roy
